Help! GPU stuck at max frequency!
Go to solution Solved by dragoon20005,
you might need to reinstall the geforce drivers too
OC software will mess up the driver settings
So I was trying to overclock my gpu (see parts list) with EVGA Precision X and running furmark and now it is stuck at the maximum frequency. I tried restarting, switching the bios switch on the card, and unpluging the card, none of which have worked. What the heck is going on!?!?!?
Also I tried uninstalling Precision X and then reinstalling it, only to find that you cant download it anymore so I downloaded MSI Afterburner.
Parts:
EVGA 780
Intel i7 4770k 4.3 GHz
Asus ROG Maximus VI Hero
Gskill TridentX 2400MHz
Corsair RM850
post-60338-0-04615200-1408592890_thumb.p
https://linustechtips.com/topic/201237-help-gpu-stuck-at-max-frequency/
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
