So after upgrading to Windows 8.1 my streaming has become really annoying. (might just be a coincidence) But lately, every time i want to play any game, the first time i click, i get extremely laggy, choppy, and just horrible gameplay. Then after restarting both the PC and Shield and retrying, i get a black screen on the shield. But the PC still displays the game. My internet speed is 28mbps download, 5.something upload, and 21 ping. I get the same connection on both the PC and the shield. This is extremely annoying because any time i want to relax and play, i end up running to my PC annoyed. I hope someone here can help fix this, because i really dont want to go to the Geforce forums :P
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/200642-shield-portable-help/
What router are you using?
"Rawr XD"
https://linustechtips.com/topic/200642-shield-portable-help/#findComment-2720148
sorry forgot to mention that.
I have the ASUS RT-AC66U
https://linustechtips.com/topic/200642-shield-portable-help/#findComment-2720180
Lol, well the router isn't the issue.
Plus, GameStream is not going off of your internet connection if you're playing on the same network, it's using the network speed of the router.
Sounds like the issue is either drivers or the connection between your PC and the router?
https://linustechtips.com/topic/200642-shield-portable-help/#findComment-2720193
  • Lol, well the router isn't the issue.
Thats what i thought... My PC is connected using wifi
https://linustechtips.com/topic/200642-shield-portable-help/#findComment-2720209
Are you on the 5GHz band?
yes
https://linustechtips.com/topic/200642-shield-portable-help/#findComment-2720212
well i guess Gamestream decided to connect again and now its smooth..
But its still annoying that theres an issue at all any time!
https://linustechtips.com/topic/200642-shield-portable-help/#findComment-2720222
