I have a 290x tri-x model. During any game, watch dogs, metro, crysis, etc My max temp is 81c. Could I try to overclock a little or is the temp getting to high on stock clock speeds? 1040 core 1300 mem
CPU -  Intel i7 4770k 4.6Ghz     Motherboard - MSI GD-65    RAM - Corsair Vengeance 16 GB     GPU - XFX 295x2    Case - NZXT H440
Storage - 256GB OCZ Vertex 4 ssd, 1TB WD Blue 7200rpm    PSU -  EVGA SuperNOVA 850 G2  Cooling - Corsair H80i     Keyboard - KGParadise v60 w/ cherry mx greens
Mouse -Theron  Sound - HyperX Cloud
https://linustechtips.com/topic/200325-questions-about-overclocking-a-290x/
Those temps are abnormally high for stock clocks with a Tri-x
Thats what I was thinking.
find the max fan speed you're comfortable with with some game noise in the background (for instance 60%) and set that speed in msi afterburner for around 70-80*c so once your card gets to that temp your fans will ramp up to that speed.
edit-example, my cards REALLY quiet at 45% so ive set it to that between 60-70*c, bear in my my gpu's die is pretty small.
when not in game it idles along at 40% fan speed at 45*c (could have it lower but who cares)
Fan example
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
Does this look good? http://puu.sh/aZ7Dp/5f848d6986.jpg
find the typical  temp you get while gaming and add 5 degrees above and below it, thats your "gaming zone".
if you have progressive ramping fan speeds as teh fan get hot the fans ramp up....then more air is moved so it cools down and the fans slow down...so it gets hotter and the fans ramp up, and down, and up, and down... hence why i have that flat spot.
i dont have a tri-x (want one..) so i dont know what the typical temps are and i dont know if your using headphones so cant hear yor pc or your typical gamign volume or do you play loud games with explosions or do you play quiet rpg's?
ramp the fan speed up manually 5% at a time with a youtube video playing in the background and find the point where the noise becomes encroaching/too much. thats your upper fan speed limit (like 65%?), then set that speed in that "gaming zone" range of temps.
edit- this should be a bit like what you need, give it a try and if it is too loud turn the fans down to a bearable level, if its too hot turn the fans up, if its too loud and too hot...somethings wrong because tri-x's are awesome.
Fan style 2
also, let it idle on the desktop for as long as you can (10 mins+) and find a minimum idle temp say 35*c? and set the fans speeds to like 30 or 40% (as logn as they're quiet) from 35*c-40*c that way when your on desktop and the pc's warmed up or watching a youtube video the cards still silent and will only start to ramp up once it goes into a game and exceeds 40*c
ALL of this depends on how your card behaves, this is a little guide on how to set it up, not what settings will actually work for you.
edit- redone the graphic, the graph changes with different cards and different user preferences (noise, heat levels etc)
ramp the fan speed up manually 5% at a time with a youtube video playing in the background and find the point where the noise becomes encroaching/too much. thats your upper fan speed limit (like 65%), then set that speed in that "gaming zone" range of temps.
brb..
Lately I've been steady 80-81c while in game.
I play mixed games
Around 65-70% is where it becomes to audible for me.
Edit:
http://puu.sh/aZ987/640b81de0a.jpg
Ended with this after taking a look at yours.
I play mixed games
well id try setting it to 65% between 75-85*c and then do some gaming and see if it exceeds 85*c (you'll likely hear it if it does), IF it does try 68% fan speed and retry.
bear in mind the 290's from amd came at 95*c so they'e happy to warrant that, what temps your okay with is upto you.
also as i said, find the idle temp for desktop and set the fans to a low enough speed that even when the rooms quiet...you cant hear them.
i can set my fans to 35% but i set them to 40% because its still silent and the line that ramps up 9to the gamign zone) is more gradual, the more vertical the lines rise the more noticable it will be.
redone my example go check it out.
Are you saying you're having 81-82 oC at 65-70% fan usage ?
No sir. This was just at whatever the fan happened to be at. Just now doing the custom fan speeds and what not.
this is probably pretty close (give or take on the idle/gaming temps) bear in mind i dont know how it sounds...
final design
Got this during a unigine benchmark and metro last light opened in the background
http://puu.sh/aZ9YC/dcc0706e32.png
Current | Min | Max
Current | Min | Max
try 40% at upto >45*c
65% at 75-85*c.
your max temp of 73*c means you're only just into the flat bit of the gaming zone, if you're okay with a few more degrees you could knock it down 5% and make it quieter.
About 15 mins in playing Metro Lastlight it stayed steady 70-71c. Is this still to high? Tops out at 74c during some spots.
Was using this http://puu.sh/aZc1u/2d0c048667.png
