Hi Guys
Just wanted to know if anyone has cleaned a reference 7970 mine seem to have a lot of dust on the fan blades.
Both are curretly out of warranty .
Any advise on how clean them do's and don'ts.
They are currently not over heating during game play but I was just thinking of doing some preventative maintenance was not sure how to go about it.
Your advice is appreciated.
https://linustechtips.com/topic/200103-cleaning-reference-dual-7970s/
Sucking the dust out with from the fan fins with a dyson vaccum didn't work very well. Tried that already they still look pretty dirty, which I am guessing is hindering their performance.
I would use compressed air to blow the dust out instead of using a vaccum. If you want better temperatures, I would try replacing the thermal paste on these cards:http://linustechtips.com/main/topic/10418-how-to-change-your-gpus-thermal-paste-with-pictures/
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
  • Q-tips (cotton swabs)
  • Can of compressed air (used for cleaning / dusting electronics)
  • Static-free cloth
  • Paper towels (can come in handy)
You can disassemble the cooler for a bit easier cleaning if you wish...this voids the warranty though.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
On the side of the GPU there are roughly 6 black screws. Unscrewing them allows the top shroud to come off to give you better access to the fan fins and the cooling fins. You might want to do this because my 290 had dust packed in across the cooling fins
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
Thanks guys will let you know how i go.
I'd be interested to hear. It dropped my idle temps 4C
