Air 540 vs Node 804
Solved by Syraz,
540 takes a big foot print but lots of room
240 has a smaller footprint, still has ample room inside,
I dislike the hdd mounting on the 540 being on the bottom of it.
the 240 has a HDD cage and sdd cage, but the HDD you NEED a flat 8pin connector or it wont fit to use.
I myself like the size and space of the 240, can fit all and more of what I would put in a build..
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
4
5
ken43 ·
Posted in Troubleshooting5 -
7
thedood2k ·
Posted in Power Supplies3 -
2
DARTHDIVIDER0213 ·
Posted in Troubleshooting8
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
