Whats the question?
This.
Plus, why the mismatched memory?
Replace one with an identical stick, or replace both.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/199800-desktopram-help/#findComment-2708144
My motherboard is sabbertooth 990fx r2 what type of ram will I need so far I have 4 gigs of ram 2 gbs each one is a kingston and the other a nanya in dual channel? ?
DDR3 1600MHz CL 9 is what you're looking for - go for 1x 8GB or 2x 4GB kit
The most common result of insufficient wattage is a paperweight that looks like a PC
https://linustechtips.com/topic/199800-desktopram-help/#findComment-2708195
Someone post me a link to good ram off newegg...im looking for 8 gigs 4 gigs sticks gskill is good
I've got Ripjaws Z in my currrent system (4x4GB, mind you)... i'm happy with it, but then again, i've been happy with basically every DIMM set i've ever had.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231585
https://linustechtips.com/topic/199800-desktopram-help/#findComment-2709252
yes they will work on your mobo
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/199800-desktopram-help/#findComment-2710915
