So.... Right now I play with 800 DPI and 1.95 sensitivity in Counter Strike: GO
I hear often that pro players don't play with nearly that high of sensitivity, and I'm wondering if my sensitivity is just too plain high to be accurate.
I just recently switched to this sensitivity, so do you think I should get a lower sensitivity before I get too used to this one?
Thanks.
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/
mine is way higher and im decent ly acurate, its mostly my skill to gett better, i have a 24500 dpi and 4.99 sensitivity
im also kinda a sniper so i should turn it down
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705067
Found this info on reddit. It was apparently written by NiP Fifflaren ;)
I am using 2.35 sens, 400 dpi, 1000 hz, 0.75 zoom sens and 1024x768 in res =)
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705070
Play with what feels comfortable to YOU. I don't understand why people ask for sensitivity/dpi settings.
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705084
Thanks.
Don't try to copy the pros. Use what's comfortable for you!
Search for the tao of cs, and download it. It's older, during 1.6 iirc. However, it can still be applied to modern fps games and of course, CS:GO.
just a small sneak peak
Here's his accomplishments -  http://en.wikipedia.org/wiki/Ronald_Kim
i7 7700k @ 4.9ghz | Asus Maximus IX Hero | G.skill 32gb @ 3200 | Gtx 1080 classified | In win 909 | Samsung 960 pro 1tb | WD caviar blue 1tb x3 | Dell u3417w | Corsair H115i | Ducky premier dk9008p (mx reds) | Logitech g900 | Sennheiser hd 800s w/ hdvd 800 | Audioengine a5+ w/ s8
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705124
I just play at 1080p, and in-game I have 5.56 sensitivity, and my mouse is set to 450 DPI.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705143
Thanks for all the advice guys.
Rank?
Master Guardian 2
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705170
They have ranks in cs now? Yeah... I feel old now -_-
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705179
Master Guardian 2
silver 1, will you help
My Rig
Total: $2074.22
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705193
You just need to have as many wins as possible.
If you have more friends playing CS:GO, get 4 of them, and form a team, play competitive together, and communicate with microphones. Usually, if you are Silver 1 and your teammates are also Silver ranks, you will play against similarly ranked players, so it should be a fun match. The more matches you win, the better your rank will be. Losing matches will get your rank down.
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705240
Lower is usually better (up to a certain point). Especially in CS since you don't have to do sudden 180°s. You can simply be more precise with a lower sensitivity, some pros use 80+cm for a 360° (that's probably uncomfortable for the most people), see if you can get to 35cm - 45cm and if it still feels okay to you.
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705252
yeah i just end up againt non ranked players, they have to have a emplem to be ranked right, im trying to get some friends to play so it shoul be fun
My Rig
Total: $2074.22
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705334
I keep telling people on here to sign up on esea. It's the quickest way you'll improve your game.
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705355
what is esea
My Rig
Total: $2074.22
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705395
what is esea
http://play.esea.net/
You'll play against amazing players. You'll get owned at first but it's the only way you'll get better at the game. They do organized scrims, pugs, and matches.
Plus they track stats and things of that nature.
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705405
so will i be playing against pro player and stuff when im a nublet, seems alot like people being allowed to smurf
My Rig
Total: $2074.22
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705451
You'll eventually get it. Trust me, everyone that plays cs does.
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705479
ok, im guessing i should learn some spray control and adjust my sensitivity until perfect and get a custom crosshair
My Rig
Total: $2074.22
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2705507
Using 0.5 sens, 400dpi, 1000hz, 0.75 zoom and 1920x1080 res.
A huge plus of having a large mouse pad such as the Qck+ is that you can have lower sens and still make alot of shots.
I've been asked in the past if having such low sens settings effects gameplay, the only thing I can say is that if a player is behind you you're already dead.
Corsair 800D - i7 3930k @ 3.2GHz – HIS 2 x 7970 - ASUS Rampage IV Extreme Motherboard - 32GB Corsair Dominator Platinum RAM - 2 x Corsair Neutron GTX 250GB in raid 0 – Corsair 1200i PSU | BenQ XL2411T 144hz monitor | Sound Blaster ZxR | SteelSeries Siberia V2 | Steelseries Qck+ Na'Vi | Steelseries Sensei [RAW] mouse | Tesoro Colada G3NL Keyboard (Cherry MX Red)
https://linustechtips.com/topic/199553-csgo-sensitivity-setting/#findComment-2719632
