Your in South Australia like me. The best place is to order online from www.pccasegear.com, if you go to cooling, then water cooling you will see the water cooling items and you can find your prices there.
i dont water cool myself but i will be looking into it when i do my next build
https://linustechtips.com/topic/19918-australian-water-cooling/#findComment-235789
CPU Waterblock: Koolance CPU-380i
GPU Waterblock: Watercool Heatkiller Hole Edition Full Nickel
Fittings: All Bitspower Fittings
Resovoir: Bitspower 250ml
Pump: Swiftech MCP-655
Radiators: All Alphacool Rads
Fans: Gentle Typhoons AP-15s
You can't walk out of your own story - Rango
https://linustechtips.com/topic/19918-australian-water-cooling/#findComment-236053
