Not for all of them, many new PSU's are coming out with let's say a technology which makes the fan turn off when the PSU is and almost no load or at low temp
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/199154-psu-with-fans/#findComment-2702390
Please don't repost threads. If you didn't get any answers then you should have bumped the thread.
http://linustechtips.com/main/topic/199154-psu-with-fans/#entry2699752
Some PSUs that have come out recently stop the fan when the PSU is cool enough. Is it possible that the PSU is just quiet enough so that you can't hear it over the AC? Or maybe the fan turns down a lot when it gets cooler?
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/199154-psu-with-fans/#findComment-2702487
No, I've seen lots of PSU's with crappy fan profiles like the AX860i for example.
He's complaining about the fan profile being agressive, even the ax860i suffers from this issue.
https://linustechtips.com/topic/199154-psu-with-fans/#findComment-2703247
There are some psus that have semi-passive cooling where the fans will turn off when not needed. There are also psus that have fans that vary in speed.
I don't think your psu does either and it might just be the noise of the AC masking the noise from the psu fan.
https://linustechtips.com/topic/199154-psu-with-fans/#findComment-2705815
I normally don't repost when i get no comments it's just there wasn't any views So I was like maybe it was the title -_-
You could edit the title by pressing the edit button on your post and press "Use Full Editor".
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/199154-psu-with-fans/#findComment-2709503
