Computer specs.
CPU: FX 8350 (Stock Speeds 4.0)
GPU: (Changed) GTX 760 2gb OC'd Reference card.
Mobo: ASrock 980de3/u3s3
Memory: 2x4 gb Kingston Hyper Beast Ram, and 1 8gb PNY Ram stick.
Case: NZXT 410 with 6 fans.
CPU Cooler: Corsair H60 (Intake to radiator, running 31 degrees idle and 50 under load) (Thermal Paste: Arctic Silver MX-4)
PSU: Thermaltake TR2 600w PSU, i've had it for 3 years and its still running strong.
HDD: 750 gb
Idk but i can't play a single game without stuttering, It only happens while turning. Can't even run Archeage on Very High without dropping to 40 fps. I mean i did pay 300$ for the GPU, not seeing a real boost in preformance, compared to my MSI/OC gtx 750 1gb card...
https://linustechtips.com/topic/198999-stuttering-issues-need-help/
Momentary pauses, is that normal?
Use the quote button so he knows you replied to him :)
it could be the games that pauses to load such as need for speed undercover
Maybe, idk... i'm just being weird. I changed my power settings to Performance, and now my CPU at core speeds is idle at 45-48 idle, and 51 under load. Its pretty hot, but it should be fine, right?.
your setup seems to be okay, no bottlenecks. i guess it's something wrong with the game.
Try this, backup your registry first.
http://forums.steampowered.com/forums/showthread.php?t=1043281&highlight=Multimedia+Class+Scheduler
* Open regedit
* Go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile
* There will be an entry for network performance throttling, default value is 10; set it to FFFFFFFF hex (willl look like 0xFFFFFFFF to the right of the entry)
* Reboot
I got issues with the multimedia class scheduler causing severe stuttering in my games after switching from Cable to DSL
via the network throttling "feature" it has.
Made the Registry change and the stuttering disappeared 100%.
* Open regedit
* Reboot
I'll try this out :).
