Help :)
Go to solution Solved by Shd0w2,
You should be fine , but make sure to crossfure the apu and gpu for better performance, if you can.
Hey Guys! Just wanna ask if how many Watts do I need after I get a new GPU
Processor: AMD A8-5600K 3.6Ghz
Motherboard: MSI FM2-A55M-E33
RAM: 8GB 1600Mhz
Graphics Card:None ATM (Planning to buy Sapphire R7-265 2GB GDDR5)
Storage:1TB Seagate
.. and after I upgrade will there be any bottlenecks?? sorry if dumb questions I'm new to this  :)
CPU: Intel Core i7-4790K @ 4.0GHz | COOLING: Corsair H100i Liquid Cooler | MOTHERBOARD: ASUS Maximus VII Formula ATX | MEMORY: Corsair Vengeance Pro Series 16GB (2 x 8) DDR3-1866 | STORAGE: Intel 730 Series 480GB SSD + Seagate Barracuda 3TB HDD | PSU: Corsair AX860i 80+ Platinum | GPU: ASUS GeForce GTX 780Ti DirectCU II (2-Way SLI) | CASE: Phanteks Enthoo Luxe (Black) | DISPLAY: ASUS PB278Q 27.0" (2560 x 1440) | KEYBOARD: Razer BlackWidow Chroma | MOUSE: Razer Deathadder Chroma | SOUND: Logitech Z906 5.1 Speakers / Razer Kraken Chroma | OS: Microsoft Windows 8.1 (64-bit)
https://linustechtips.com/topic/198965-help/
Basically any PSU from a well known manufacturer will run that.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/198965-help/#findComment-2697064
Thanks Guys! Nice Community new here very fast response  :D  :D
https://linustechtips.com/topic/198965-help/#findComment-2697167
