Optical, I dislike the acceleration of laser mice.
https://linustechtips.com/topic/198915-optical-vs-laser-mice/#findComment-2696439
Optical all the way. All the mice I've had with tracking problems or annoyances have been laser. Something huge has to happen in the world of laser sensors to make me give them another try.
That and I find a lot of laser mice die on me.
https://linustechtips.com/topic/198915-optical-vs-laser-mice/#findComment-2696498
Yes, laser mice have acceleration issues, but put an optical mouse on a black mouse pad like the QcK and move it relatively fast than it will skip quite a bit (From personal experience). Actually if you even put it on a mouse pad with a graphic it will skip as well
https://linustechtips.com/topic/198915-optical-vs-laser-mice/#findComment-2696508
I have a black mouse pad with a really detailed custom graphic that's some years old. I've never seen skipping issues. It is the optimal material though,
https://linustechtips.com/topic/198915-optical-vs-laser-mice/#findComment-2697762
I use UT3 as a testbed game whenever I get something new that might affect gameplay and/fluidity of the game....like new GPU, mouse and even keyboard. I have tried a number of mice using this game, and the only mouse that affected gameplay was the Tt Level 10M mouse, but not due to the laser sensor it has, rather it has to do with how comfortable the mouse feels in my hand. I have both laser and optical mouse and, after tweaking the dpi, all the mice I use more than get the job done...other than the Level 10M that is. To me, I have been playing with laser sensor mouse for a long time, and have so used to them that gaming with laser mice isn't a problem.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/198915-optical-vs-laser-mice/#findComment-2698197
