I have downloaded a freenas iso and put it on a 16gb usb driver. I try to boot from it to install it to my boot hdd in the server and it just shoes a black screen and nothing changes. I have never used freenas so I have no clue.
https://linustechtips.com/topic/198896-freenas-issues/
Would it not be a better option to go direct to their forums for a fix?
Someone may have an answer, but it'd be easier to go direct to their forum.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696100
I will if this doesn't work. I love this forum  and answers come faster. I want to have this done tonight if I can.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696112
It may sound stupid but are you booting off of the correct drive?
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696133
Did you find a guide to follow or did you just throw the iso on a usb?
Iso on usb. Also can't boot a ubuntu server iso thoiugh.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696147
Yes. I wish that was the issue.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696150
Ok, Make sure you installed it loaded the iso onto the drive correctly. Use this guide:
http://doc.freenas.org/index.php/Burning_an_IMG_File
EDIT:
Its also possible your motherboard doesn't support USB booting, if it is really old.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696154
EDIT:
Tried from cd :(
booted and looped error 5 and error 6
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696233
Tried from cd :(
Can you give me a run down of the hardware you're installing freenas on?
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696266
It is a hp compaq 5800 workstation
I got 3 of them for free.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696288
Alright, Did you get the errors after you installed FreeNAS or did you not get that far?
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696307
Never got that far. I saw a boot menu and then the errors started. Thanks for your help so far.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696312
You're welcome, I am trying to research error 5, and 6 as I have never came across them before, how ever information is scarce, the most I can find is related to the hard drives, Try disconnecting the harddrives, and loading the installation media, I know I seem like I am going out on a leg here, that's kind of because I am haha. If that doesn't work,  can you add more information, as to the error I mean. Also make sure the installation media is correct for the architecture.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696345
I am booting an img further than before so we shall see.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696364
Stuck on
"Waiting up to 5 seconds for ixdiagnose to finish... done."
That is all that is showing for the last 2 min.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696371
Stuck on
I did a quick search and read that it does take a while, even upto 10 minutes. If it goes beyond that I would hard reset and try again.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696390
It ran but now soft update inconstancy keeps popping up. Sorry I don't know anything about freenas.
*EDIT*
That ran but now I get "Enter full pathname of shell or RETURN for /bin/sh:"
I assume that I should use "RETURN"
What do you think?
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696413
*EDIT*
What do you think?
I read more related to the harddrive, it is very possible that it is the problem, I remember having issues installing FreeNAS on a big harddrive, Try installing from the CD onto the USB drive, and boot off of the USB drive if you can, if not, Swap harddrives if you have one handy
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696444
I am running of a usb img.
I did RETURN and git
"mount: /dev/ufs/FreeBass3: Invalid argument
mount -o ro /dev/ufs/FreeNass3 /conf/default/ect faild: dropping into /bin/sh"
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696456
I may have to point you to the FreeNAS forums, I am personally running out of ideas... You could try an older version of FreeNAS I am still running 8.2. Other then that I am fresh out and Google doesn't seem to be much help.
Sorry I couldn't have helped better.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696506
Thanks for trying. I am just going to do ubuntu server or server 2012.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696528
It is actually recommended to run FreeNAS from a USB drive because if it is installed on a HDD, you will be unable to make use of all the space of the HDD.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696531
It was a 74gb raptor so no big deal but I am going to use ubuntu server or server 2012.
https://linustechtips.com/topic/198896-freenas-issues/#findComment-2696729
