Water Cooling Loop Question
Go to solution Solved by Excon,
It won't make a difference
Hello Folks.
I'm currently working on a loop.
My question is, would it make a temperature difference if I make my loop like this:
Res->Pump->Rad->CPU->Rad->Res...
instead of:
Res->Pump->Rad->Rad->CPU->Res...
I'm on mobile so I can't make a drawing, but I hope you get my question.
Thanks!
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/198585-water-cooling-loop-question/
Well you might say that having the water cooled right before it goes in the cpu is better... but that's a fraction of a degree so it doesn't matter which option you go with. Pick the one that looks the best to you.
How does that look?
I'll use red coolant.
post-6955-0-43174300-1408185220_thumb.jp
Is the pump and res behind the motherboard tray or farther down in the picture? I'm a bit confused.
It's behind the tray.
It's an Air 540 case so there's plenty of room.
