Hey.
Yesterday i particioned my drive to tree letters.
C. D. E.
I did this with aomei particioner.
Now i click the start button on the case and the gigabytes bios flash screen comes up and then windows starts after that everything turns black and only a cursor left on the screen so a black screen with a cursor i can only move the cursor and thats it.
Please help.
I need my pc for writing a college thing.
https://linustechtips.com/topic/198567-help-i-need-my-pc-now/
When partitioning a drive I suggest using the built in drive manager that comes with windows.
Try pressing Ctrl + Alt + Del, then open task manager and in the applications tab click on "New Task...", in the text bar put in explorer.exe, then click Ok.
Otherwise I have no clue what to tell you.
https://linustechtips.com/topic/198567-help-i-need-my-pc-now/#findComment-2691559
Try putting in the windows USB/CD and boot from that, do a repair.
After doing what he tries.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/198567-help-i-need-my-pc-now/#findComment-2691653
the ctrl alt delete dosnt work
https://linustechtips.com/topic/198567-help-i-need-my-pc-now/#findComment-2699375
What parts? What OS?
i7-3770K @ 4.5GHz, ASRock Z77 Extreme4, G.Skill Sniper 8GB DDR3 1866 @ CL9, ASUS GTX 780, CM HAF XM, Samsung 850 Pro 256GB, WD Black 1TB x 2, EVGA SuperNOVA G2 850W, BenQ XL2420TE 24" 144Hz @ 1080p, CM Nepton 280L, Noctua Industrial IP67 2000RPM 140mm PWM Fan x 6
https://linustechtips.com/topic/198567-help-i-need-my-pc-now/#findComment-2699426
Use the CD to attempt a repair!
Download it online if you can't find the CD you used.
https://linustechtips.com/topic/198567-help-i-need-my-pc-now/#findComment-2699687
