Yes it comes with a boxed cooling solution. However it's a little underrated for the i7, it uses the same supplied with the i5. So don't do anything like running prime95 or something.
https://linustechtips.com/topic/198205-i7-4770k-help/#findComment-2687479
It comes with a CPU cooler, the thermal's pre-applied, and it's enough for general use. At that level of a product, I'd rather splurge and get an aftermarket CPU cooler.
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/198205-i7-4770k-help/#findComment-2687482
The stock cooler can be just fine for overclocking. You would need to test it yourself. In my case, I get good temps with the stock cooler with my CPU overclocked. As far as aftermarket coolers go, the Noctua NH-D14 is a good one as well as the bequiet! Dark Rock Pro 3.
https://linustechtips.com/topic/198205-i7-4770k-help/#findComment-2687548
