My CPU Fan has a manual (physical) RPM controller but I have to always have it on high and I can't turn it down any or I get warning's that speed to slow for cpu fan or something like that, does anyone have a way to fix this? and it is the loudest fan in my case
https://linustechtips.com/topic/19767-cpu-fan/
Where do the warnings occur? Might be a BIOS setting.
https://linustechtips.com/topic/19767-cpu-fan/#findComment-233457
Can you raise the target temperature and lower the minimum fan settings?
https://linustechtips.com/topic/19767-cpu-fan/#findComment-233459
When I boot up my computer in the bios.
Okay. Might be a setting in the BIOS.
https://linustechtips.com/topic/19767-cpu-fan/#findComment-233465
so try and look for fan speeds in the bios and change it higher than see what happens?
Something like that. Anything that relates to the potential fix.
https://linustechtips.com/topic/19767-cpu-fan/#findComment-233477
