No problems! It'll work just fine. Those 2-pins are optional, you need to use them for cards that require 6+8 pin.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/196927-2x6-pin/#findComment-2670694
could somebody tell me  if  I could power my asus R9 270x which needs 2x6 pin connectors with my power supply which has 2x6+2 pin connectors?I mean putting 2 6 pin connectors and let the 2pin connectors out . the power supply is a b500 from coolermaster.
Yes you can. Just leave the two pin connectors and plug in only the 6 pin part.
"Rawr XD"
https://linustechtips.com/topic/196927-2x6-pin/#findComment-2670823
