and are all videos up scaled? thanks
CPU- i7 5960x MOTHERBOARD- Asus Rampage V extreme RAM- 32gb Corsair Dominator Platinum ddr4 2800mhz GPU-  2X EVGA GTX 980 SC in SLI PSU- Corsair ax860 CASE- Corsair Obsidian 750d COOLING- EK cpu+dual gpu custom loop (ek supremacy evo, dual gtx 980 copper/acetal waterblocks) MOUSE- Logitech g502 proteus core KEYBOARD- Ducky shine 3 cherry mx blue switches and blue LED MONITOR- Samsung u28d590d UHD  STORAGE -  120 gb samsung 850 evo ssd, 960 gb ocz trion ssd OS- Windows 10 pro http://pcpartpicker.com/p/jtP8GX
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/
What exactly do you mean with "4k upscale"? Upscaling 1080p videos to 4k?
yes
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2660987
yes
Upscaling is just converting one resolution to a higher one. In the case of converting a 1080p video to a 4k video one pixel will just be converted into 4 pixels. It doesn't increase picture quality, that's about it. There is legitimate 4k content out there, but most stuff, especially on youtube, is just upscaled.
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2661016
Upscaling works by analysing the image and using interpolation to work out what the missing pixels should display, so in the case of upscaling 1080p to 4k each pixels is quadrupled so that 1080p fits onto a 4k screen without stretching it or introducing artefacts
(Also some monitors/tvs upscale the frame rate, basically it analyses 2 frames of video, lets say a foot ball is in the bottom left of the screen,and ends up at the top right in the second screen, interpolation means the TV will invent the frames between it, showing the ball moving gradually instead, this creates more fluid motion but bad interpolation can look blurry)
No there are 4k 6k and even 8k cameras available on the market, some smartphones can record native 4k too!
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2661023
Here is some encoded 4K content @ much higher bitrates than Youtube allows for its 4K video resolutions.
http://box.houkouonchi.jp/4k/
Some are better than others
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2661026
so if i recorded with a note 3, and watched it on my computer, would it be native 4k, or up scaled?
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2661042
The file would be in native 4k
It would actually be downscaled, to run on your monitor (if your monitor is not 4k)
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2661057
4K only looks as good as the bitrate allows.
Note 3 - 4K does look pretty nice, shits on YT's 4K quality, but obviously phones recording 4K also has its limits on bitrate and quality too.
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2661072
Thank you so much for showing me this!
I will cherish those videos... FOREVER!
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2661088
Many Youtube videos are just upscaled because youtube allows for a higher bitrate at that resolution.
Show me these upscaled videos.
I download plenty of 4k videos for playback on a 4k TV and I have yet to run into anything upscaled.
4k cameras are not a big deal anymore, haven't been for a couple years now.
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2661172
Most gameplay videos on youtube are upscaled. They look like crap if you leave them at 1080p because the bitrate is way too low.
https://linustechtips.com/topic/196191-how-does-4k-upscale-work/#findComment-2661294
