Hey! I just chose the components for my first build and was wondering if there's anything I should change on it. Also, was wondering if it could run games like DayZ, Rust, Arma, etc, with decent FPS. http://pcpartpicker.com/p/djrGhM
I plan to do gaming and maybe YouTube/streaming.
Also, if someone could recommend a good, budget monitor that would be great. (21-24")
Thanks!
https://linustechtips.com/topic/196178-my-first-build/
that mobo is the problem
VRMs are not cooled
pick the Gigabyte GA-970A-UD3P
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/196178-my-first-build/#findComment-2660854
If you can fit the 270 in that budget it would help a lot, mind you I admittedly only glanced at it.
The OS could be had for cheaper someplace like G2A, so I hear that is.
Otherwise just find a better MOBO fit, as the above said.
Do not  as I  do, and  not  as I say. Instead do as you may..
HSS Revenir: CPU=i7 5960x @4.5GHz Heatsink=Corsair H100i MOBO=ROG Rampage 5 RAM=Kingston HyperX Predator 16GB @3000MHz SSD=Corsair Neutron GTX 480GB GPU=R9 295x2 PSU=Corsair AX1500i OS=Windows 7 Ultimate
https://linustechtips.com/topic/196178-my-first-build/#findComment-2660864
Why are you typing in italics
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/196178-my-first-build/#findComment-2664090
The aesthetic appeals to me, why does your avatar feature a motion picture?
Why do like 90% of people use their Samsung phones in that horrible scribbling font
Beats me, never owned a Samsung phone either.
https://linustechtips.com/topic/196178-my-first-build/#findComment-2667154
Italics that small and in that font is so hard to read on the LTT dark theme. Please stop
"Rawr XD"
https://linustechtips.com/topic/196178-my-first-build/#findComment-2667166
My avatar moves because it's a .gif file.
Please stop using italics, that's not how they are intended to be used and it's hard to read
https://linustechtips.com/topic/196178-my-first-build/#findComment-2672010
No actually it's not all that hard to read on the dark theme.
Source: Using the dark theme.
Motion pictures were never intended to be used in avatar profiles, you do so anyway.
https://linustechtips.com/topic/196178-my-first-build/#findComment-2674619
By that logic still pictures were never intended to be used for profile pictures. You're doing two things wrong now
https://linustechtips.com/topic/196178-my-first-build/#findComment-2674802
It's your logic mate, I just turned it around, so you're only refuting yourself here.
https://linustechtips.com/topic/196178-my-first-build/#findComment-2675190
