Gpu Help
Go to solution Solved by Freaky_spider,
Would that even work?  Cpu uses 65 watts
yea,
stock 750ti doesnt even have 6 pin connectors, so max tdp of that is 75 watts :D
 GTX 750 (ti)
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/195878-gpu-help/#findComment-2656757
yea,
https://linustechtips.com/topic/195878-gpu-help/#findComment-2656792
Should work for now but look into a PSU upgrade
 The Wannabe is no longer. Replaced by the Flotilla. If you replace every part of a computer is it still the same computer?
Survived the Survivor 2299
Audio Engineer, Lighting Programmer, Video Engineer, FOH.
https://linustechtips.com/topic/195878-gpu-help/#findComment-2656802
Maybe a cheap PSU like the VS series from Corsair just for that 80+ efficiency.
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
https://linustechtips.com/topic/195878-gpu-help/#findComment-2656835
and a little higher wattage
https://linustechtips.com/topic/195878-gpu-help/#findComment-2656847
