Need help finding a fan controller
i have decided to get an nzxt h440 case but i need an internal fan controller since the grid runs the fans  at 12 volts . I need an internal fan controller that i can control through a software or even if i need to open the case to control the speed  i dont care but i just need one were i can adjust the fan speeds but it needs to be able to control 5 fans . Pls i really need help guys .
https://linustechtips.com/topic/195709-need-help-finding-a-fan-controller/
Connect fans to mobo, Use mobo software. You could connect power cable of grid and adjust whole hub as one speed.Or any of hundrets of hardware solutions.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I just purchased a phanteks Pwm hub. allows you to control up to 12 fans from the Pwm connector and a data connector for the extra power. Then just control the first fan which controls the rest.
Unit is small like a box of matches. Cost me 9 aud
http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_511&products_id=28287
