Hello there,
my first post here and also my first custom build.
  • CPU    AMD A10-5800K (stock cooler)
  • MB      Asus F2A85-V
  • RAM    8GB (2x4) G-Skill Sniper @1866
  • PSU    be quiet! Pure Power 300W
  • SSD    Kingston SSDNow V300 120GB
  • Case   Cooltek K1
It's a pretty good system but thats just my opinion. What do you guys say?
I noticed that the CPU gets pretty hot and I was thinking about a better CPU cooler. The only problem is that the case is pretty small and I had no chance to fit in a Cooler Master Hyper 212 Evo for example.
post-21950-0-13945100-1407754040_thumb.j
post-21950-0-38611500-1407754049_thumb.j
post-21950-0-19782700-1407754062_thumb.j
post-21950-0-19202500-1407754070_thumb.j
https://linustechtips.com/topic/195629-first-apu-build/
get the stock cooler out now! otherwise great first build
Specs
https://linustechtips.com/topic/195629-first-apu-build/#findComment-2653468
It's great!
Although I question the use of an older APU A-7600 would be good and the Kingston V300 (and it's use of cheap NAND)
Looks good :) I'm sure you'll be able to find a good low-profile cooler from a decent brand.
Looks like the Hyper 212 evo should fit though...
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/195629-first-apu-build/#findComment-2653516
Personally, I just love Noctua coolers, I am using a Noctua NH-L9i (Intel) on my little HTPC and I must say that it cools really well, there is also NH-L9a (AMD). Yes, it costs a bit more than usual, but for the quality? Otherwise, really nice build :)
When I started with mine I couldn't even afford a SSD :D
EDIT: Scratch my first recommendation, try out NH-L12, that should fit also and is more cost effective.
https://linustechtips.com/topic/195629-first-apu-build/#findComment-2653577
Hello there,
  • MB      Asus F2A85-V
  • Case   Cooltek K1
Pretty awesome APU build! I'll follow this for updates :)
DAZZA THE DRAGON, MEMER AND KING OF DORITOS AND MOUNTAIN DEW.
https://linustechtips.com/topic/195629-first-apu-build/#findComment-2653584
Thanks everyone for the answers :)
It's great!
ssdnow doesnt work, this ssd is as slow as a HDD with its new firmware
For the games I'm playing, the APU does more than I expected. The SSD is also pretty fast (I haven't done any firmware update so far) and until now, I had no problem with the 120GB or the 60GB one. :)
It's ~1cm too large :( I could drill some holes into the side panel but that would be too much ghetto style :D
...try out NH-L12, that should fit also and is more cost effective.
Sorry, but I really don't like the brown and beige color of the Noctua fans. Besides, it would look a bit strange, combinding the (mostly) blue, black and white with some brown. :wacko:
The Arctic Freezer 7 PRO Rev.2 is lower than the evo, it's good and cheap also comes with preapplied MX-2...
Thanks for the recommendation. Is there a difference between this one and the 64 model? I mean, apart from the fact that the 64 can be mounted in 4 ways and the other only in 2? ;)
https://linustechtips.com/topic/195629-first-apu-build/#findComment-2654007
good build! only the Psu is a bit overkill i think. you could have got away with a corsair v350, a lot cheaper (at least where i am) and i have never had problems with it.
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
https://linustechtips.com/topic/195629-first-apu-build/#findComment-2676310
  • 7 months later...
I'm not quiet sure, if I should continue this thread or create a new one.
I want to upgrade the graphics card a bit. The HD 7660D isn't enough for Cities: Skylines... :D
Now I could get this SAPPHIRE HD 7750 1GB GDDR5 for nearly nothing but I guess, it wouldn't work woth my 300W power supply.
I already ran a 7900 GT with a too small power supply and it worked great, but I also could have been lucky with this. :unsure:
I also would like to test Dual Graphics mode with both graphics cards :wub:
https://linustechtips.com/topic/195629-first-apu-build/#findComment-4476258
  • 5 months later...
Maybe it's time for an update on this machine.
After adding a Club 3D Radeon HD 7750 to get some more FPS in Cities: Skylines and having it in dual graphics configuration with the the APU, I'm unsatisfied again. The frame rate is ok for playing but it could be better. Also, I'm waiting for Planet Coaster or RollerCoaster Tycoon World to be released. For both games, my system probably wouldn't be good enough.
My plan is, to follow the guys in this thread and add a R9 270 to my system.
I now that my PSU isn't powerful enough for that and that I've to upgrade that as well. I tried several PSU calculator sites with recommendations from 320W to 450W. In addition to the specs above there is a second optical drive in it and I switched my sound card to an ASUS Xonar DX which needs a floppy connector :D
Should 430W be enough?
https://linustechtips.com/topic/195629-first-apu-build/#findComment-5870522
I was never really happy with my 5800k. It seemed the throttle under load no matter what I did, even with an H80i on it. For PC intensive games it was garbage even after I added a HD7950 to the mix. As for your question 430W would probably be okay although depending on your budget you could probably get a decent 500W PSU for for a few more euro to get a little extra headroom for future upgrades.
Main Rig:  CPU i5-4670k   MOBO Gigabyte Z97N-WIFI   GPU GTX 980ti    RAM 8GB  STORAGE 128GB ADATA(OS)/250GB Samsung 850 EVO(APPS)/3TB WD Red
AUDIO: AMP/DAC TEAC AI-301DA SPEAKERS: Cambridge Audio SX50 Phones: Philips Fidelio X1
https://linustechtips.com/topic/195629-first-apu-build/#findComment-5875840
For now I'm totally happy with it. But i have to note that I was used to an P4 with 3GHz before this one, so it was a huge step for me :D
The PSU is now already ordered an will be an be quiet! L7 530W. That should be enough :)
https://linustechtips.com/topic/195629-first-apu-build/#findComment-5887184
