what is the difference between these two cards
Solved by Rorgash,
i mean performance wise, id like to know why diference in price , i know they look different but that does rly mean anything
no performance difference worth noting, the one with 2 fans runs cooler, but the one with the reference cooler will keep your case cooler so if you dont have good airflow in your case that one will run cooler.
other than that the ref design tends to run a little bit slower
