Using Flash Drives as Main Disks
Go to solution Solved by hojnikb,
these badboys have pretty crappy controller, but i guess for a simple linux install they should do the trick. Certanly better than flash drives.
Hey guys!
I'm thinking of building some servers (mostly just game servers like Space Engineers, Minecraft and maybe a website and NAS) and was wondering about the using 16gb SanDisk Cruzer flash drives for the main drives, since they're only like $8.
The 4 rigs are old HP workstations with Core2Deo E8400s and no graphics cards, and I don't want to waste that much money on Hard Drives that are susceptible to failure and SSDs that cost a bomb. I managed to obtain the rigs free, and I'm on a tight budget.
What do you all think?
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/195048-using-flash-drives-as-main-disks/
The speed of those drives would cause a HUGE bottleneck for games like Minecraft
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
And Flash drives are not that reliable either look at this HDD  HERE
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
That's an IDE drive though. The computers came with 250gb WD blue drives but I want to take those and use them in my own computer when I build it. :/
Aren't flash drives better at random Read/Writes than normal hard drives?
I only need 4-8gb per computer.
No, they are actually way way worse (sometimes even as bad as 0.01MB/s). So yeah, its really not reccomended, that you run OS from flash drives, since its gonna be slow and trouble will appear. Flash drives are not meant for running OS, since their controllers are very very simple (think 70s computers simple) and their garbage collection and wear levelling is not tuned for such workload.
+°´°+,¸¸,+°´°~ Glorious PC master gaming race :wub: ~°´°+,¸¸,+°´°+
BigBox: Asus P8Z77-V, 3570k, 8GB Ram, Intel 180GB & Sammy 750GB, HD4000, W7
PiBox: Rasberry Pi, BCM @ 1225Mhz ^_^ , 256MB Ram, 16GB Storage, pIO, Raspbian
The OS will be TinyCoreLinux, so not much IO will be needed for that, though not sure about Minecraft, Space Engineers and a NAS. I've seen NAS systems running off a USB before so I don't think it's that intensive, right?
I just did some tests and the SanDisk Cruzer has 4.3 Read and 1.4 Write at 4k Random, tested with Crystal Disk Mark 3.03. The 5400 rpm 2.5inch drive on my laptop has 0.34 and 0.85 for the same test, and the 3.5 inch hitachi 7200 rpm SATA/600 Drive on a desktop has 0.69 and 1.37 for the same tests, so I think the Cruzer will be faster
Though I'm not sure about the reliability of the flash drive or the performance consistency. All drives were about half full at the time of testing.
At $8 for 16gb, it's $0.5/GB, and SSDs like the MX100 are still about $60 for 120GB so the price/GB isn't that high.
Ideally I'd get a small SSD, but I don't know where to get very small, reliable, cheap SSDs :/
@TheRunningOtaku
Just get a used 32-64GB ssd from a decent brand and you're good to go.
But once you go up the capacity, this ratio decreases in favor of ssds ... for example mx100 256gb comes at 43c per GB
The cheapest is a $44 SSD from Kingston at 60GB (It's using bad NAND but I won't complain, it's cheap)
for 4 computers it's $170+ for SSDs vs $32 for 4 16gb USBs
I know in Chromebooks they use 20gb SSDs but I'm not sure where to find those :/
Would http://www.amazon.com/KINGSPEC-KSD-SA25-7-SATA-II-CHANE-Solid/dp/B00JYB99O4/ref=sr_1_8?s=pc&ie=UTF8&qid=1407660590&sr=1-8 be a good choice? For 4 PCs it's only $80, though I'm not sure about the performance of it and the reliability since it's a small brand. Does anyone have any experience with this drive?
