i repair it?
If you have knowledge in circuit design or soldering, you MIGHT be able to.
Normandy - Intel Core i5 3470, 8 GB Corsair Vengenace LP, EVGA GTX 960 SSC, Gigabyte GA-Z77M-D3H-MVP, WD Blue 1 TB, Seagate 320 GB (steam), Seagate 320 GB (experimental, second OS, etc), Windows 8.1 + Ubuntu 14.10
Garrus - HP Stream 11
https://linustechtips.com/topic/195033-help/#findComment-2645097
Just duct tape it idiot
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/195033-help/#findComment-2645103
this work?
me only have plastic tape
<snip>
At this point it is pretty clear this is a troll.
https://linustechtips.com/topic/195033-help/#findComment-2645124
this work?
-Snip-
You may loose some stability and compatibility...
https://linustechtips.com/topic/195033-help/#findComment-2645138
yes me only claer tape
i no afford new ram :(
Well sucks for you bud.
https://linustechtips.com/topic/195033-help/#findComment-2645141
Easily identifiable lol.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/195033-help/#findComment-2645145
Just rma it or get new ram
RMA is RAM with the letters rearranged.
Both have 3 letters.
Add them together you get 6.
6/2 is 3
HALF LIFE 3 CONFIRMED
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/195033-help/#findComment-2645160
