R9 270x (Sapphire Dual-X OC) Questions
Solved by Aniallation,
Thank you for the welcome and for the tips,
what about the memory? is1 1560 ok/quite good or should i keep testing with it?
Bumping it up will increase memory bandwidth, but also increase heat coming from the memory. Stick with the GPU overclocking itself, and bump up the memory by 50MHz or so.
rayu ·
Posted in New Builds and Planning4 -
Ordinaal ·
Posted in New Builds and Planning2 -
sumgreenday ·
Posted in Displays8 -
6
1
avg boywithuke fan ·
Posted in Troubleshooting0 -
11
NetanelC ·
Posted in Troubleshooting1
