External Hard Drive solutions?
Solved by siberiansteel11,
As for transfer speeds. Its 5400rpm drive. It isn't very fast even in SATA. And you say its old? It might be older than USB3. Consumer USB3 haven't been here very long. So if the drive side plug is blue, then you have USB3. Otherwise its USB2. Can you see the drive on BIOS when its connected by SATA? You might need to reformat it in OS just in case there's something wrong with that.
says usb 3.0 though But Crystal Disk info gave it a Bad Status so I'm throwing it but Thanks and no for some reason I can't see the drive in bios when I'm using sata so i guess this is broken
