So I'm looking at getting a new ssd drive in the near future and I'm wondering if this m.2 SSD will work with my motherboard
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820249045
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128716&cm_re=gigabyte_GA-z97mx-gaming_5-_-13-128-716-_-Product
My concern is whether or not it will physically fit in there. and will it be as good or better than my current Samsung 840 pro? which I obviously will be keeping. Will it interfere in any way with my gtx660?
Don't know much about storage, if you need more info my rig is in my profile.
Dubs are better than subs
https://linustechtips.com/topic/194526-general-m2-confusion/
it won't be in the way.
any motherboard make isn't that stupid to make something not fit in with something else there or next to it.
I was thinking of operation as well as physical compatibility, don't know anything about the m.2 platform or how it works.
Would m.2 be better as an OS drive than sata 3?
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2637037
should be fine. the macpro works off m.2
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2637044
I can't speak as to physical compatibility, but honestly, as long as
there isn't a seriously superior controller and NAND solution on an
m2 SSD, it might have improved sequential reads and writes, but it's
not going to do all that better at random I/O (which is most of a
typical usage scenario's workload), so don't expect any miracles.
Having said that, if you can get an m2 SSD for a comparable price to
a SATA3 drive, all other things being equal (reliability, longevity
and so on), I don't think it's unreasonable to use one personally
(well, at least I haven't heard of any serious caveats, it's just
that at this moment, it's not really as superior in practice as the
marketing material would have you believe AFAIK).
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2637067
Well they seem to be fairly cheap at the 60 gig range, I'm just wondering if it's worth it to use one as an OS drive since I have a single m.2 slot in my motherboard. Either that or as a small games drive maybe? Basically just "its there, is it worth using?". I have no idea if it will using it will take up a sata slot the way some other storage solutions do, even though it doesn't physically plug into one of the sata slots.
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2639186
If it takes up a SATA slot I'd say it would depend on whether you
can find a better m2 or a better SATA3 solution (price/performance,
or other things which are important to you). Also maybe try to find
out if your M/B has any quirky behavior with regards to the m2 slot
and so on (I'd expect no, but you never know).
If it is an actual proper dedicated port and you can get a good
m2 drive for an acceptable price, I don't really see a reason not
to use it, either for the OS or games, whichever is more important
to you. It's not like an m2 SSD is something radically different
from a SATA SSD, the implementation may be a bit different in the
details, but in the end it's still primarily a controller connected
to a few NAND packages and an interface to the outside with some
added bits to make it all work smoothly.
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2639269
What is the minimum size SSD you would use for an OS drive for windows 7?
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2639285
Hm, good question. I've mainly been using Linux in the past few years.
I have been running Win7 on one machine since last February though. The
rig has a 120 GB SSD, about half of it is full (64.5 GB), and I don't
have all that much stuff installed on it.
I suppose it would depend on what additional software you intend to
install, but personally I don't think I'd go lower than 120 GB unless
it was like a really minimal install for a special-purpose build.
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2639303
So to add to my confusion, I find out that the SSD I linked in the original post might be non compatible with my motherboard, because while it is an m.2 SSD, it's based on pci-express-x 2
The issue is that there also exists Sata 3 Based m.2 SSD's, and I cannot determine which one my motherboard uses. I believe that it is Sata 3 based because according to the motherboard manual, when an M.2 SSD is installed, the Sata 3 ports 4/5 will become unavailable. However it does not state outright that I must used either a Sata 3 or a pcieX2 based m.2 SSD.
Am I correct? So confused with this lol......
I am now considering this http://www.newegg.com/Product/Product.aspx?Item=N82E16820148798 M.2 SSD, will it work?
Perhaps not, did some deeper digging on gigabyte's website to find this
"1 x M.2 PCIe connector
(Socket 3, M key, type 2242/2260/2280 SATA & PCIe SSD support)" So does that mean PCIe SSD will work? Aren't those supposed to be faster than standard Sata SSD?
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2641318
Hm, yeah, M.2 can be a bit of a mess. The different sort of connectors
are keyed to prevent incompatible devices being used in the wrong sockets.
Wikipedia has a section on it, I recommend having a look at that.
According to your post, your motherboard's socket is keyed with key M,
which would indeed indicate PCIe SSD compatibility.
To be really sure, you could always ask the manufacturers directly,
I must honestly admit that while I've read a few article and some
technical documentation, I haven't personally played around with
M.2 yet, so there might be some caveats I'm still unaware of.
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2643330
  • 2 weeks later...
more important than the size (they all fit m.2 enabled mobo's) is the pci-e lane assignment. is the m.2 taking up an x1 or x4 pci-e lanes?. this affects multi-gpu (xf, sli) configs. also some m.2 are sata which would be the same (except physical size) as sata3.
if the m.2 has pci-e controller than it would be roughly 60% faster on boot. if sata3 you would get better RL speed from RAID array ssd.
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2707467
This seems like one of those things where people should probably wait until an M.2 drive is released which actually takes advantage of the new interface, better controller, better flash etc. M.2 NGFF drives don't really seems to yield a huge performance boost right now, even though, in theory, they're capable of double the speeds of Sata 3. It seems like one of those things where people are better off waiting for an M.2 drive with a better controller and better flash memory which will actually take advantage of the new standard
CPU: Intel Core i7-4770k | Mobo: MSI Mpower Max | Cooling: Cryorig R1 Ultimate w/ XT140 front Fan | GPU: EVGA GTX 770 Dual SC SLI | Case: NZXT H440 | Case Fans: Phanteks PH-140SP x5 | PSU: EVGA Supernova P2 1000W | RAM: 16GB Crucial Ballistix Tactical Tracer | SSD: Kingston HyperX 3k 120GB | HDD: Seagate Barracude
Keyboard: Razer Blackwidow Ultimate 2013 | Mouse: Razer Deathadder 2013 | Headphones: Sennheiser HD438s | Mousepad: Razer Goliathus Control | Monitor 1: Benq XL2430T | Monitor 2: BenQ RL2455HM
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2707799
Think of a M.2 drive as an ssd without an enclosure. If you're really space constrained like with a laptop or a NAS it makes sense. On the desktop side though it's nothing more than a curiosity, especially if you already have an ssd installed. A lot of dollars for very little benefit.
Sir William of Orange: Corsair 230T - Rebel Orange, 4690K, GA-97X SOC, 16gb Dom Plats 1866C9,  2 MX100 256gb, Seagate 2tb Desktop, EVGA Supernova 750-G2, Be Quiet! Dark Rock 3, DK 9008 keyboard, Pioneer BR drive. Yeah, on board graphics - deal with it!
https://linustechtips.com/topic/194526-general-m2-confusion/#findComment-2710162
