Best Value CPU Cooler
Go to solution Solved by TheTiger,
Oh ok, thanks. I´ll take a look at it, But where did you find it for 32€?
ok, I lied, it's 34€ :D
blub
Performces so freakin amazing 8)
EDIT: Also come and say "Hi" in the "German Talk" Thread (Offtopic section ;) )
Hey guys,
I got a i5-4670K with a stock Intel CPU Cooler, and I´d like to overclock it to 4GHz or at least keep the CPU-Boost active all the time, when gaming, can someone please recommend me a good CPU-Cooler/Heat Sink for the money. It shouldn´t be more than 80 €.
Thanks in advance.
https://linustechtips.com/topic/194227-best-value-cpu-cooler/
blub
https://linustechtips.com/topic/194227-best-value-cpu-cooler/#findComment-2632754
Yeah I looked it up there too :D, just wondering, is thermal paste included?
I would wonder if not...nearly in every box is a bit of thermal paste (most times just enough for one installation).
https://linustechtips.com/topic/194227-best-value-cpu-cooler/#findComment-2632764
Noctua D14/D15 are the best
Dark Rock Pro
Evo 212
Corsair H80i
https://linustechtips.com/topic/194227-best-value-cpu-cooler/#findComment-2632786
Dark Rock Pro
Evo 212
Corsair H80i
Those are good coolers, but non of them can beat the Macho in performance per € ;) @least not over here in Germany.
https://linustechtips.com/topic/194227-best-value-cpu-cooler/#findComment-2632822
H80i could be interessting, because it´s a watercooler.
Costs you 84€ and will just perform as well.
Just to give you guys an idea how prices are over here:
D14: 74€
D15: 99€
Dark Rock Pro 3: 67€
H80i: 83€
Note that these are the cheapest prices avaliable!
https://linustechtips.com/topic/194227-best-value-cpu-cooler/#findComment-2632844
D14: 74€
D15: 99€
H80i: 83€
Yeah so the Thermalright Macho is the one :)
https://linustechtips.com/topic/194227-best-value-cpu-cooler/#findComment-2632853
ye, but in europe its different. also different by the country.
I know, I looked on german amazon for the prices....
https://linustechtips.com/topic/194227-best-value-cpu-cooler/#findComment-2632875
I don't think you have to spend so much on a CPU cooler for a 4670k
MY RIG | AMD FX-8320 | COOLER MASTER HYPER 212 EVO | ASUS M5A97 R2.0 | CRUCIAL BALLISTIX SPORT 8GB DDR3-1600MHz | WD CAVIAR BLUE 1TB | ASUS RADEON R9 280 3GB DIRECTCU II | CORSAIR 300R | CORSAIR CX 600W 80+ BRONZE | 1x COOLER MASTER SICKLEFLOW 120mm | WINDOWS 7 ULTIMATE 64-BIT | DELL S2240M 21.5' 1080p <p> | G602 | G710+ MOBILE| ONEPLUS ONE 64GB RUNNING OXYGENOS  | NEXUS 4 16GB RUNNING LOLLIPOP | NEXUS 7 2013 32GB RUNNING LOLLIPOP
https://linustechtips.com/topic/194227-best-value-cpu-cooler/#findComment-2632974
