Hi guys first off my laptop was struck by lighting 2 months ago so I am trying to post this with my HTCm8 it's not going to be perfect so the grammer Nazi's can suck it.
I am building a new rig for the first time for under for around $2500. Shooting for it being on my desk before 01/01/14 mostly for gaming and some 3D and a little picture and audio editing
I have done alot of research over the past year so I have a semi solid list of parts.
Case corsair 450D
Motherboard Asus hero
Processor Intel I7 4790k
Gpu asus gtx 780ti
Ram Kingston hyperx fury 1866 16gb 4x4
Psu corsair Ax860i 80+platinum
Blue ray drive
LG 14x Internal BDXL Blu-Ray Burner Rewriter WH14NS4The
The Hard drives
Boot drive
Corsair Neutron GTX 240GB
Games
Corsair Force LX 512gb or wd black 1tb still undecided
Mass storage
Wd green 2tb x 2
Cooling
Corsair h100i
Corsair sp140 red led x2
Corsair sp120 x6
There it is
So now down to what your thoughts are. and if I am missing something or for a extra couple hundred should I go complete water cooled custom loop and all. want it to look good and stay under $2850
Also I am kinda holding out to see what the nvidia 800 series has to offer.
And ddr4 is kinda being elusive as to when we see it on the market.
I have a pretty good 23" 1080p HP monitor but i am looking for a single 27" 2k monitor with 100% color gamut that has a high refresh rate 5ms or less around $600-$700
I am open to suggestions thanks for the help
https://linustechtips.com/topic/194090-first-build-ever/
$2500 what? usd au etc
please read before posting
http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
use the quote button if you want my help
Specs
https://linustechtips.com/topic/194090-first-build-ever/#findComment-2630909
Yes, @SAV1OUR is right, please tell us your currency, peripherals etc... Use the link he gave here it is again: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
https://linustechtips.com/topic/194090-first-build-ever/#findComment-2630914
$US have all the Logitech parifarals I need. just want suggestion on a decent monitor to buy when I have the cash after I am done building the computer
Sorry I am a noob to forums.
https://linustechtips.com/topic/194090-first-build-ever/#findComment-2630977
The Hard drives
Boot drive
Games
Mass storage
Wd green 2tb x 2
Cooling
Corsair h100i
Corsair sp120 x6
There it is
Get a 2x8GB memory kit. It is more efficient and will allow you to upgrade memory if that is ever needed.
Get a single ssd. For not much more than the price of the two Corsair one can get a 1TB drive. Use logical volumes if you really want to keep things separate.
If the intent is to RAID the WD Green, get WD Red. Red are designed for that. Green are not. Otherwise get a 4TB drive.
It seems like a real waste of resources to replace five stock fans with fans costing as much as the case. Especially since they are all from the same manufacturer. Although I can appreciate LED fans for the front.
You might consider using a Nzxt Kraken X61 cpu cooler or the Corsair H110. If you are contemplating a custom loop you might look into the Swiftech H220-X which can be a nice intermediate step.
As good as the AX-860i psu is, it seems like real overkill. Unless there is an unmentioned plan in place to add a second gpu you may want to consider getting something in the 650W range.
https://linustechtips.com/topic/194090-first-build-ever/#findComment-2631077
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($139.99 @ Newegg)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($139.99 @ Amazon)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($139.99 @ Amazon)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card (2-Way CrossFire)  ($392.98 @ Newegg)
Case: Corsair 450D ATX Mid Tower Case  ($114.99 @ Micro Center)
Monitor: Asus PB278Q 27.0" Monitor  ($478.99 @ Amazon)
Total: $2508.87
Generated by PCPartPicker 2014-08-08 03:45 EDT-0400
Specs
https://linustechtips.com/topic/194090-first-build-ever/#findComment-2631149
I am not doing a raid setup the reason I have two green drive s is I have allot of music and alot of pictures and videos and cad files having 2 drives in theory allows multiple things to be done at the same time with less latency for example one truck pulls 2 trailers vs 2 trucks pulling 1 trailer each I also don't know yet if I want a ssd storing all of my games on it I have a metric ton of them and I hate load screens with a passion so if I had a ssd for my games and a ssd for my OS and software it would be perfect the goal here I guess is for the computer to be able to do 7 different things at once with minamal interruption
The reason for a 800w plus psu is I have no clue what I am doing after I am done building this thing I may a year from now put 1 more 780ti in it. depending on if there was not already a better card out by the time I build this thing like a gtx 790 or 880ti plus water cooling and maybe a death ray and the ax860i is really cheap on Amazon right now so why not
6 fans four push pull on the rad one in the back one on the bottom and there all the same pressure fans I may do a water loop but I am still doing research
https://linustechtips.com/topic/194090-first-build-ever/#findComment-2631244
The analogy is far from a good one. Having multiple channels/drives is only going to improve performance if you can actually use them concurrently. Loading a game is going to use whatever drive has the game. Have the o/s on the same drive or another drive. Heck have each game on a different drive. It is not going to make that one game load any faster.
If you really want to improve ssd performance consider a PCIe x2 or x4 card - Plextor PX-AG512M6E. Or, and I don't recommend this, put two ssd in a RAID 0 array.
Same holds true for the two green drives. But more so as green drives are not the fastest "trucks" around. I expect a single 4TB 7200 rpm hdd will outperform non-raid 2TB green drives every time - higher density and lower rotational latency.
https://linustechtips.com/topic/194090-first-build-ever/#findComment-2634745
