Hey guys,
I've been having issues with my Nvidia Shadowplay for the last few days. It just all of a sudden started doing this...
In any game, doesn't matter what game whenever I record it seems to record it twice as fast. Like when its done and I go watch it, its playing back really fast and the audio is all choppy.
Of course, I uploaded a sample footage to YouTube and the video looks fine -_- but you can hear how the audio is all choppy. Now look at the video and imagine it like 3x faster
Any help would be great. If you need to know my GPU is a GTX 660 2GB OC.
(Sorry if this is in the wrong section, feel free to move if it is)
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/
Weird. Never seen this problem before :(
What settings are you recording at?
Do you have the latest graphics drivers and the latest GF experience?
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2627703
Just updated them today, and I was recording at 60fps @ 1080p
Hmm thats weird...
Is there anything else running on your PC?
Does this happen with every game you try to record?
Try to change the settings to 50MBps and 30fps
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2627773
Hmm thats weird...
Nothing else is running, and yes every game I have tried so far it does this. Currently it's at 50MBps and 60fps. Do you think changing it to 30fps will work?
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2627830
Have you tried reinstalling ShadowPlay?
Download and install it from here: http://www.geforce.com/geforce-experience/shadowplay
I had some weird issue with it which caused it to not record sound properly, but a simple reinstall fixed it. It's still in beta so this kind of stuff is understandable
Specs: i7-3770K | Asus R9 290X | 32GB DDR3 | GA-Z77-UD5H | RM 750x | Define R5 Arctic White | macOS 10.14.5 & Windows 10
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2627886
Try 30fps and see what happens.
If it still does it your only option is to uninstall geforce experience and reinstall it again to see if that solves any issues.
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2627935
Okay I'll try that and get back to you guys. Thanks!
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2627947
Where do I change the fps? I can't seem to find it :/
In the 'quality' settings on the small shadowplay window (with the power switch on it) click 'custom'
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2628860
Okay I am gonna try it now and let you know :)
ok cool :) good luck
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2628968
Still same issue :(
:( darn
and you said uninstalling it and reinstalling didn't work either?
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2630814
Oh sh*t xD forgot about that part. Let me try that first, and I'll probably get back to you later on.
Ok good luck :)
tty tomorrow sya
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2630890
So just GeForce Experience? I don't need to re-install any of my drivers, right?
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2633755
First try just reinstalling GeForce Experience. If that doesn't work then try reinstalling the drivers too.
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2633782
Ok I'll try that now. I just downloaded the latest version from the link you included. Which is weird because I had updated my GeForce Experience to this version yesterday...
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2633804
:( darn
Would you look at that? It works. Thanks guys, just a simple re-install is all it took :D
I feel so stupid now
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2633849
Congrats :D you're welcome!
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2633986
Never mind, did it again -____-
aww that sucks :(
what GPU driver version are you using
https://linustechtips.com/topic/193849-nvidia-shadowplay-help/#findComment-2634417
