Need help installing Teamspeak 3
Go to solution Solved by Vacsol,
cd ~/[location]
chmod u+x ./TeamSpeak3-Client-linux_x86-3.0.16.run
So, I have the TS3 .run file sitting on my desktop doing nothing, since I forgot how to install it. Can someone help me out? OS is Elementary OS .2 32-bit.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/193315-need-help-installing-teamspeak-3/
cd ~/[location]
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
chmod a+x file.run
./file.run
I believe chmod +x works as well but someone correct me if I'm wrong.
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
chmod a+x file.run
./file.run
a+x and +x both install for all, u+x is for user
chmod +x ; ./TeamSpeak3-Client-linux*.run
What did I do wrong? It's probably because I'm tired I missed something painfully obvious.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
replace the asterisk with the file version
cd ~/Downloads (assuming saved in Downloads folder, otherwise where you saved it)
chmod u+x ./TeamSpeak3-Client-linux_x86-3.0.12.run
I'm awake enough to know it's 3.0.16. ;)
You need to name the file you want to add permission to. I thought you would remember by seeing chmod and ;
Nope. I forgot almost everything except sudo (apt-get, apt-add-repository, autoremove, etc.). The basics.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
I was too lazy to try to do any work, so I used my secret googling ability and that's what Ubuntu forums told me.
Alright, everything is in the folder in my Downloads... So.... How do I go about installing it like a normal program? It works in the folder, just it isn't installed. Know what I mean?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Mind sharing your wallpaper? Pls. :) <3
Lenovo/IBM ThinkPad T61 Widescreen 15.4" 1680x1050
Intel Core2Duo T8300 2.4GHz | 3GB DDR2 from Hynix | SATA II Patched bios (Middleton) | Samsung EVO 850
Arch Linux | Linux 4.3.X x86_64
Sure thing. Here you go.
http://linustechtips.com/main/uploads/gallery/album_679/gallery_37587_679_313824.jpg
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Thank you very much! :) <3
No problem.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
