What happens if you dont hit reset?
https://linustechtips.com/topic/193150-onboard-red-led/#findComment-2618209
My screen is blank, system is on, but my screen doesn't detect anything.
Are your GPU drivers up to date?
Is your GPU powered with the correct PCIe 6 and 8 pin cables?
Is your GPU in the top PCIe slot?
https://linustechtips.com/topic/193150-onboard-red-led/#findComment-2618271
Usually speaking if a red light is above the GPU, it means that there is something faulty with it or the connection.
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
https://linustechtips.com/topic/193150-onboard-red-led/#findComment-2618296
Yes to everything.
Did you install the latest motherboard drivers from the ASUS website? The ones that come on the disk that comes with the mobo are usually older.
Also try updating your bios.
https://linustechtips.com/topic/193150-onboard-red-led/#findComment-2618313
