Hello and welcome to the LTT forum
I have a few suggestions that I will edit in.
That one would be a good choice as well as this.: http://www.aquatuning.us/water-cooling/gpu-water-blocks/gpu-full-cover/9935/aquacomputer-aquagrafx-for-gtx-480-gf100-nickel-plated-version
Hope this helped  :)
https://linustechtips.com/topic/193040-water-block-for-480/#findComment-2616845
yes
https://linustechtips.com/topic/193040-water-block-for-480/#findComment-2616847
Trying to cool my 480 on the cheap but its a bit difficult to find a waterblock for it. Never heard of this brand but would this work?
http://www.ebay.com/itm/like/171282779694?lpid=82
There's most of the time the problem... custom watercooling and the word cheap doesn't really come together. You'll get for what you pay for, usually a bunch of issues. And cheap waterblocks are quite risky TBH, because ther's always the chance that they shorten the PCB of your card.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/193040-water-block-for-480/#findComment-2616927
It is not difficult to find a waterblock if you look. This is one I would trust for example http://www.aquatuning.us/water-cooling/gpu-water-blocks/gpu-full-cover/9542/aquacomputer-aquagrafx-fuer-gtx-480-gf100?c=6470
For safety, if it is not a well known waterblock manufacturer, do not buy from them. Or at the least google reviews for them.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
https://linustechtips.com/topic/193040-water-block-for-480/#findComment-2617034
Don't ever buy one of them. I did, and bad things happened. It leaked around the seam, and I pulled the threads on one of the ports. Didn't even tighten it up that hard. Biggest waste of money!!
I got my new one from AquaTunning as mentioned above. Well worth it!!
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/193040-water-block-for-480/#findComment-2651442
