https://linustechtips.com/topic/193029-top-case-under-100/
can i put the optical drive in h440
No.
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/193029-top-case-under-100/#findComment-2616674
does the define r4 have good airflow with included fans?
yes. And it has spots for 4 more fans
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/193029-top-case-under-100/#findComment-2616689
Enthoo Pro or Arc Midi R2. If you want silence then get the R4.
hehhehhehhehhehhehhehhehhehhehheh SWIGGITY SWOOTY I'M COMING FOR THAT BOOTY hehhehhehhehhehhehhehhehhehhehheh
huehuehuehuehuehuehuehuehuehuehuehue LINIXTEKTEPS R DE BES I LUV LINUX huehuehuehuehuehuehuehuehuehuehue
https://linustechtips.com/topic/193029-top-case-under-100/#findComment-2618739
Not really. Enthoo pro has much better
https://linustechtips.com/topic/193029-top-case-under-100/#findComment-2618756
Arc midi r2
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
https://linustechtips.com/topic/193029-top-case-under-100/#findComment-2647201
