ok distilled water or something else?
Up to you really. If you're going with clear tubing, you might want to go with a coloured coolant as clear coolant can become discoloured over time.
Have a look through Mayhems' coolants and find one you like.
https://linustechtips.com/topic/192743-how-much-coolant/#findComment-2612219
I got a pastel colour additive form mayhem
PLEASE USE PCPARTPICKER.  My rig: http://pcpartpicker.com/p/ZBmWjX
https://linustechtips.com/topic/192743-how-much-coolant/#findComment-2612233
If you have a colour additive, you can either go with distilled water or a clear coolant. Personally, I would go with a clear coolant as they (I think) have chemicals to prevent algae and other build up, as well as not needing a silver kill coil (not needed really, but advised with water)
https://linustechtips.com/topic/192743-how-much-coolant/#findComment-2612260
The tubing I got (Primoflex) comes with an anti microbial
https://linustechtips.com/topic/192743-how-much-coolant/#findComment-2612275
So I ordered all the parts of my loop and i'm wondering about how much coolant I need. I have a 360mm rad and a 240mm rad as well as a dual bay res, Swiftech apogee xl, and 2 295x2 blocks. How much should I get?
As others have said distilled water and a kill coil is general best practice but nothing wrong with coolant with dye in it just can lead to more maintenance in some applications. Also a positive is that dye can show very small slow leaks easier as it will stain the paper towel even if it dries. Also a 1 litre should be enough. I have a similar setup to you and 1 litre of EKWB's coolant was enough after bleeding and topping up.
EDIT: actually you may need more depending on the capacity of your dual bay res. I am only using a tube res which may be smaller.
https://linustechtips.com/topic/192743-how-much-coolant/#findComment-2612320
I would go with distilled water
also i like the amount of posts you have...
Nvidia is to Dr Dre Beets as AMD is to KFC.
One makes you broke, the other you can get more of and have a midnight snack from the fridge when hungry again. Once you go Nvidia, you go broked, turn into an Elitist, or get the incorrect amount of VRAM.
- WCCFTECH
 I was only 9 years old. I loved Fifflaren so much, I had all the NiP merchandise and matches pirated. I prayed to Fifflaren every night before bed. Thanking him for the life I have been given. Fifflaren is love I say. Fifflaren is life. My dad hears and calls me a fuckhead. I knew he was just jelly of my passion for Fifflaren. I called him a Sw@yer. He hits me and sends me to go to sleep. I'm crying now, and my face hurts. I lay in bed and it's really cold. A warmth is moving towards me. I feel someone touching me. I feel someone touching me. It's Fifflaren. I am so happy. He whispers in my ear; "this is my pyjama". He grabs me with his powerful Swedish hands and puts me on my hands and knees. I'm ready. I spread my ass cheeks for Fifflaren. He penetrates my butt-hole. It hurts so much but I do it for Fifflaren. I can feel my butt tearing as my eyes start to water. I push against his force. I want to please Fifflaren. He roars a viking roar as he fills my butt with his love. My dad walks in. Fifflaren looks straight into his eyes and says; "He is a ninja now". Fifflaren is love, Fifflaren is life
https://linustechtips.com/topic/192743-how-much-coolant/#findComment-2612384
To be honest, it doesn't really matter what coolant you get as long as you get good quality tubing as you did. There have been colored coolants left in systems for 5 years that have been fine and it is usually the plasticizers from tubing that causes issues from what I understand. I used just under 2L for my system. Specs in sig. I spilt a little but if you're buying $3000 of GPU's how much is an extra liter really going to matter?
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/192743-how-much-coolant/#findComment-2612611
just get coloured tubing it doesn't have to cloudy effect that mayhem fluids do though but i am lazy so i like my computer to be easy to clean and cleaning out radiators with a shitty fluid in them thats blocking the flow of water isnt worth it i would rather play my games then spend my time cleaning out my custom loop
https://linustechtips.com/topic/192743-how-much-coolant/#findComment-2612682
