Has anybody experience with the Cooler Master N300 case? The cooling on the case looks good...
Decent, but what's your budget?
https://linustechtips.com/topic/192619-cooler-master-n300/#findComment-2610512
about $100 including fans, I was thinking about corsair 120mm silent fans or be quiet silent wings 2. Also the cooler master silent fan si1 looks good, it is quite a bit cheaper but a bit lower cfm.
Go with the phanteks enthoo pro. Includes enough fans and is great! Great fans to!
https://linustechtips.com/topic/192619-cooler-master-n300/#findComment-2610568
^this, or an arc midi R2 and get some extra fans if you wish if it's cheap enough to, as it's a very well designed and engineered case.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/192619-cooler-master-n300/#findComment-2610596
how about the corsair 350d? You know if it's a silent case?
That's matx, and not silent, and enthoo pro is better
https://linustechtips.com/topic/192619-cooler-master-n300/#findComment-2610657
The enthoo pro looks gorgeous but not available here in the Netherlands :(
update: I think i'm going with the fractal design R4 case. Thanks for helping me !
Ah great to. Look at the fractal arc midi r2, like the define r4 but looks better and better airflow
https://linustechtips.com/topic/192619-cooler-master-n300/#findComment-2610871
