Ok guys. Im a little bit confused on how to choose the right power supply for my rig. Here is the list of my parts: http://pcpartpicker.com/p/qjVpzy
It says on the site that the estimated wattage i need is 795W. What PSU should I get? Should I get something like 850W but 80+ Gold? Should I get a 1000W 80+ Bronze or what? And I need to keep the cost low too. Thanks guys
https://linustechtips.com/topic/192173-power-supply-issue/
Why do you need a lot of hard drives and ssd? Just get a wd 1tb black and a 840 evo 250gb ssd.
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603468
first off
what is the purpose of this build?
why the 32GB of RAM?  16GB is already good enough
why dual GTX770? GTX780 6GB single or a GTX780Ti will be better than dual GPUs
I will suggest the CoolerMaster N600 Windowed case
if you just need a single GPU 600 watts is enough
otherwise for dual GTX780/Ti need 850 watts
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603472
I'd go with 950w+ to allow some headroom for expansion and overclocking.
also, if I was going for a high end rig like this, I would go for better SSDs, as the kingston v300s replaced their controllers with lower quality ones in february
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603484
@deuel18 Hello, regarding which power supply you should choose I'd advise a 850w 80+ silver-platinum certification however after looking at your pcpartpicker spec list I do believe there should be a lot of changes that can save you a couple $100-200 dollars and more power hungry components.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603513
http://pcpartpicker.com/p/VW8RYJ
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603575
I've got to say, that is terribly unbalanced, how about this:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.98 @ OutletPC)
CPU Cooler: Cooler Master Seidon 240M 86.2 CFM Liquid CPU Cooler  ($88.16 @ Amazon)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ Amazon)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  ($184.99 @ Amazon)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive  ($124.99 @ Amazon)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($109.99 @ Amazon)
Video Card: Sapphire Radeon R9 290X 4GB Vapor-X Video Card  ($623.65 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($95.45 @ Amazon)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($156.81 @ Newegg)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer  ($14.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor  ($137.00 @ Amazon)
Wireless Network Adapter: Intel 7260HMWDTX1 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($47.99 @ SuperBiiz)
Case Fan: Cooler Master R4-C2R-20AC-GP 69.0 CFM 120mm  Fan  ($5.91 @ NCIX US)
Total: $2067.61
Generated by PCPartPicker 2014-08-05 00:51 EDT-0400
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603582
Thanks. And the reason why i have it this way is because this is the end of my future update on this rig. I already planned out everything on my rig on this specification so I won't have to run on some difficulties in the future because I already know what to buy. Yes, things are changing but this is just an overview of my build at the end of my upgrades. Also the motherboard Asus Z97-A is a bit meticulous with the RAM, the mobo has specific lists of the ram brand and stuff.
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603598
it will be clearer if you list the current planned and the possible upgrades you intend to get
first off many games need ton of GPU power which the GTX770 do not have
you should be looking at the GTX780 6GB version or the GTX780Ti
dropping to just 8GB will be good enough
swapping the SSD to the Samsung Evo 250GB and a 2TB HDD
keep the PSU to the 850 watts for future SLi upgrade
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603627
you're not going to run into ram issues as long as you stick to 1600mhz DDR3, and 32gb is overkillfor gaming
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603660
Total: $2067.61
Isn't that PSU a bit too powerful for this build?
The most common result of insufficient wattage is a paperweight that looks like a PC
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603679
Yeh, kinda, an RM850 would also do nicely.
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2603933
whats with the 32GB of RAM???
drop to 16GB and get a 250GB SSD
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2604985
Yeah I will. But this config is just an overview.
How about this build?
http://pcpartpicker.com/user/deuel18/saved/dbKKHx
I'm hearing a lot of negatives about MSI mobo but their non-reference graphics card have prominent marks with cooling capabilities.
http://pcpartpicker.com/user/deuel18/saved/6BjBD3
This one is build around Gigabyte, but I'm planning to over clock and I am a beginner in overclcoking. Idk if gigabyte's mobo can handle me as a nube in over clocking.
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2643041
None of those links work
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2646188
Sorry, I erased them. I feel the real driving force on choosing parts right now is the price point.
But my point is, will MSI mobo + GPU work really good? Or should I just consider them at the very least of my list?
If I choose Gigabyte, are they that reliable? If they are, are they good at over clocking? Can I rely their mobo in over clocking?
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2647409
I'm sorry about it. Here it is
http://pcpartpicker.com/user/deuel18/saved/npH7YJ
Idk what motherboard and what brand of GTX 780 should I get though...
I want to over clock but I'm not a pro on it
I want the motherboard to last very long cus of future update to 5th Gen CPU
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2664329
What are you using the pc for ?
https://linustechtips.com/topic/192173-power-supply-issue/#findComment-2665073
