Ok so im planning on making a computer inside a table as some of you may have seen.
So here is a quick pic of what i plan it to look like. (I will make  a proper 3D one a bit later.)
So there are the components. Now i have no idea how to setup a loop for this, could anyone help? Could someone like download the image and place in arrows for the cycle or something that would be great! I will be sure to upload pics when this is down. Im hoping this layout can work, worse comes to worse i can stick a dual rad above the pump and connect up the quad a bit later. Yes this loop is way overkill but it will look cool once down. Also if a tube has to run in front of the ssds all the way back to the pump it shouldn't be an issue. Have fun guys, and thanks if someone else can work it out.
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
https://linustechtips.com/topic/191162-custom-loop-build-need-big-help/
The rads aren't overkill if anything, it's too little for dual GPU's and a CPU. If you have so much space available (and budget permitting) you should have at least a 2nd quad 120mm rad or even a third if you want overkill/killer temps-noise. There are some good tables loops out there, have a look at them to get an idea of how to run things. Two things you should keep in mind, pump below res (although I'm not sure this is a requirement in a horizontal build), secondly component order in your loop doesn't matter. You don't need a rad after every component etc.
Bert & Ernie before squirting spermie.
So more rads the better i guess!
With the how downwards thing, when i start filling it up the table will be tilted so that everything can fill up and flow but i think once its full and running being horizontal shouldn't be an issue.
Should this flow be ok?
Yep. I highly recommend you incorporate at least another 480 or 2 240's in there. Make sure you have a good pump(s) for this loop. I don't see a problem with the flow order but definitely do some research on similar builds. Typing 'water cooling pc desk' in Google should yield some interesting results. Good luck and feel free to show us the process in the build logs subsection.
Yep thats what i am doing now, thanks for the advice.
I found this on the internet:
Intead of having the single quad rad i could setup 2 like this cause i have the room. You reckon it would work?
