doesnt matter really. as long as there is no kinks or anything and it fits nice
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
Provided that the hoses are long enough, yeah sure, go ahead.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
I'm getting a Define R4 with a H100i. Do I mount the 240mm rad onto the dual 140 fans at the front?
you can use the 140 fans in push, but they'd be more of a restriction than help
over the stock fans. no, there is a dual bolt pattern that will secure the H100i to
the front bulkhead panel.
fractal-design-define-r4-front-dust-filt
