3 issues
i built my first computer yesterday when i go to plug in a hdmi wire to the gpu to the tv i get no signal i thought something was was wrong so i took it to a computer teck he plugged in into his moniter and it was fine from that is the hdmi port on my gpu bad?  its a msi gtx 760
2nd issue
when i turn on my computer it sometime takes multiple attempts to start when when i press it i can hear the fans going than stop ike its struggling to stay on than after like 30 secs of pressing. it finally turns on.  is my psu bad? its a corsair rm 750
3rd issue
my gpu is not alined with the back things you unscrew so when i put my gpu in the slot it cant be screwed down is that a issue with the mobo or the case?  my mobo is the asrock killer 990fx and my case is the corsair 750D
plz help
https://linustechtips.com/topic/190706-computer-help/
Pictures will be very helpful.
Motherboard: Gigabyte Z97X-Gaming 7 .:. Processor: Intel Core i7-4790k @ 4.7GHz .:. Graphics Card: MSI GTX 770 Twin Frozr OC 2GB
Storage: 1x 250GB Samsung 840 Evo, 1x 1000GB WD Blue .:. RAM: 4x4GB G.Skill RipjawzX 2133MHz .:. CPU Cooler: Cryorig R1 Ultimate
Case: NZXT H440 Black/Red .:. PSU: Corsair CX600M .:. Fans: 5x 120mm AeroCool Dead Silence, 1x 140mm AeroCool Dead Silence
https://linustechtips.com/topic/190706-computer-help/#findComment-2573252
coming up
the little piece on metal in the shadow is the culprit sitting right on top of a screwdown point when i tried to screw in the gpu. it  was crooked
missing one here to
missing a place to screw mother board in
installed right
https://linustechtips.com/topic/190706-computer-help/#findComment-2573278
ok i found the issues due to the fact that i cant screw the gpu on straight to secure it it wasnt working now that i have unscrewed and sitting on the floor it fixed all the issues
but idk how am i going to screw the gpu in :( considering cutting or bending the piece piece or metal
https://linustechtips.com/topic/190706-computer-help/#findComment-2573714
