What cpu for gaming build?
Solved by i_build_nanosuits,
Is it worth taking away the SSD for a better graphics card?
IMHO it is, if you are going to mainly game on this machine and don't mind sacrificing slightly longer loading time for a much better gaming experience once the game loaded...
SSD won't affect gaming performance, it only makes things loads faster...the GPU has the most impact on gaming performance amongst all the parts within your PC, so if you're building a gaming PC get the best GPU you can get!
You can always consider the SSD as a future upgrade when you'll have more money available.
