Hey everyone anyone know where to can get some cable sleeving around brissy as i wanna do some cables and  just not sure where to look
Online.
I went looking around Melbourne and all the pc stores I asked just straight away went "online"
so... yeah, http://www.gammods.com.au/
Home is where the heart my desktop is.
https://linustechtips.com/topic/189935-cable-sleeving/#findComment-2558443
  • 2 weeks later...
I've always bought all my sleeving from Nils (http://en.mdpc-x.com). It's high-quality, and not too expensive.. I've also heard that people use so-called paracord rope, you may google that if you want.
I dont like using heat shrink, I rather use super glue (see here: http://linustechtips.com/main/topic/70253-wip-redefine-r4-march-23rd-paint-putty-sand/?p=1740120, around half-way). It is far better looking imho..
Current rig: i7-5820K, R5E, 1070ti (windows), Radeon HD7850 (Mac), a bunch of SSDs and HDDs, running MacOS Mojave, Windows 10 + a bunch of debian servers on Proxmox KVM hypervisor
Laptop: MacBook Pro 13" 2017
Previous projects: Razmac G5, Server, zenbox HTPC
See my GitHub profile!
A coder/modder from Finland
https://linustechtips.com/topic/189935-cable-sleeving/#findComment-2678398
Do you know if he is out of business or something? Or will his stock be replenishing anytime soon?
Nope he posted this on his personal facebook
"Hey everyone I know I have been gone for a long time but I am back I had some personal and family issues. Infact I still have a huge family issue right now. I will be getting to LC emails and posts as soon as I can. In the mean time I can use all the prayer you can give. I have a huge change in life starting and need all the help I can get. Thanks for all of your support. If you have a question about LC or orders please send them via pm"
So i'm assuming everything should be going back to normal within the next few months
https://linustechtips.com/topic/189935-cable-sleeving/#findComment-2691989
