Hello, I've seen many threads on this forum about switching the audio output between different devices such as between speakers and headphones. I've also found out some useful audio software that may help you out.
SoundSwitch (Switch between different audio devices)
Downloadhttps://soundswitch.codeplex.com/
Images
Detailed Description
SoundSwitch is a program that runs in the background that allows the user to switch between different audio outputs, such as the front and rear audio jacks. To use the software, setup a key on your keyboard as the "switch" that alternates between the selected audio jacks. I personally have mine set to F1 since I rarely use that key, but you can set it to whatever you desire. An extremely useful software if you use both speakers and headphones, but only want them to play at specific times. NOTE: Their may be an issue where Windows won't differentiate between the rear and front audio jacks, this is due to Realtek's Audio Manager which can be fixed by going into the manager and changing the settings. It should look like this
Volume2 (Visual UI when volume level is changed)
Download: http://irzyxa.deviantart.com/art/Volume2-version-1-1-3-247-Release-340146840
Images
Volume2 is a program that displays the volume level when changed. I personally have my increments set at 2 units per click, but you can set it to whatever you want. The program also has other features such as quick volume changes by scrolling on the taskbar, this changes the volume level by 10 units instead of 2 for faster volume change. You can also customize the UI with different themes, the one in the image is the Metro UI theme/skin. Volume2 is an amazingly powerful software, it's like DisplayFusion but for audio. You can setup different hotkeys for brightness, USB safety removal, etc.
MediaMonkey (Multimedia player)
Downloadhttp://www.mediamonkey.com/download/
Images
MediaMonkey is just awesome. Way better than Windows Media Player due to it's functionality and customization. It allows you to theme the player, play videos, surf the web, etc. all in one program. It can level the audio on any track to any level you like, I have mines at 89db. It can also minimize to a MiniPlayer like in the image, or just disappear from the taskbar with the MicroPlayer. It's just awesome. the theme I use can be found here: http://www.mediamonkey.com/forum/viewtopic.php?f=9&t=68761
foobar2000 (Music Player)
Downloadhttp://www.foobar2000.org/download
Images
Realtek HD Audio Drivers
Downloadhttp://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Realtek AC'97 Audio Drivers
Downloadhttp://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
Still in the process of editing this post. Someone sticky this post? Feel free to leave any recommended software below.
https://linustechtips.com/topic/189837-useful-audio-software/
Please add Foobar2000
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
https://linustechtips.com/topic/189837-useful-audio-software/#findComment-2557052
I don't see any feature in DisplayFusion that can do that, elaborate please.
It's only in 6.0 and newer. It's a new feature. You rightclick on the display fusion task bar and there is an audio devices tab.
https://linustechtips.com/topic/189837-useful-audio-software/#findComment-2557082
Images
Images
Images
Images
JRIVER MEDIA CENTER 19 is great
https://linustechtips.com/topic/189837-useful-audio-software/#findComment-2562021
