ek ddc flow enough?
Hey guys,
In the ek kit I got an ek Dcp 2.2
Wondering if an ek ddc pump is enough for the following...
2 r290x gpu covers
Cpu block
360 rad
240 rad
The specs say it's rated at 400 lph, which to me sounds fantastic, but might not be?
The res is quite small Which caused me some concern so it left me with three options that I can see
1- get a standalone res like the photon 270 and have it drain into the return on the teeny ek res
2- Order the bigger res chamber from ek or frozen cpu
3- buy a new res and pump with the photon and d5 combo... If I really have too
Don't worry about how big the res is, it's there only for looks and easier filling of your loop. 400LPH isn't a lot considering D5's and DDC can push from 1000 to 1500 LPH.
You should be aiming for 1GPM at max pressure. Your components have about 4.6 PSI, the DCP 2.2 can only deliver 2.08 PSI. So that won't cut it.
You'll need this: http://www.frozencpu.com/products/21019/ex-pmp-248/EK_DDC_X-RES_Top_140_w_32_PWM_Pump_EK-DDC_32_PWM_X-RES_140.html
The pump is 1000 LPH and give 5.2 PSI (> 4.6 PSI).
Getting the Phonton you're talking about would be $10 more, http://www.frozencpu.com/products/21480/ex-pmp-263/XSPC_Photon_170_Tube_Glass_Cylinder_Reservoir_Pump_Combo_D5_Vario.html
