GPU rattling noise
Go to solution Solved by helping,
It's a Windforce card, there is no reason for the fan to be above 70% unless you're pushing extreme voltage.
Your temps are safe up to 85c, set your fan curve to reflect that.
It's most likely a rattling fan blade, which isn't really that uncommon when a fan goes at that high of an RPM.
I've come across this issue with graphic cards all around internet and people seems to have no idea how to fix this. I thought this thing is something unnecessary to know but I got the same problem with my new gpu I just bought, the sound drive me insane above 75% fan speed while it's always on 80%+ under load.
Haven't got any solution except to RMA or put a stick or something to make it not vibrating which is kinda dumb. I just want to know how to fix this before I give up and try to RMA.
https://linustechtips.com/topic/189141-gpu-rattling-noise/
Error: 410
https://linustechtips.com/topic/189141-gpu-rattling-noise/#findComment-2547283
