Hi all.
So im new to overclocking)
I own a gigabyte gtx 770 4gb oc. I use gpu tweak to overclock and its not very stable.
I boost gpu clock for 40mhz and gpu voltage to 1210. according to your database those settings should work.
I have notice in hwmonitor that my voltage stays the same always. its 0.862v and it doesnt change at all until the system freezes.
Should i change the min voltage settings?
https://linustechtips.com/topic/188366-gtx-770-oc-need-help/
Hi all.
 Could you list the CPU and PSU you are using?
https://linustechtips.com/topic/188366-gtx-770-oc-need-help/#findComment-2536123
