A first timer needs help !
Go to solution Solved by PokémonTrainerFour,
will a vga to hdmi adapter be just as good quality
why wouldn't it be
Or, you could get a card with the proper ports.
I think it's one or the other (dedicated GPU or integrated GPU), but I can't remember for the life of me.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/187321-a-first-timer-needs-help/#findComment-2520450
Im pretty sure you need to use the GPUs ports, but you can just get an adapter.
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/187321-a-first-timer-needs-help/#findComment-2520468
Pretty damn sure you're right.
No if you have a GPU installed you need to use the GPU's ports.
No you don't, you can just leave the GPU installed and have it be useless with the monitor plugged into onboard.
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/187321-a-first-timer-needs-help/#findComment-2520469
why wouldn't it be
https://linustechtips.com/topic/187321-a-first-timer-needs-help/#findComment-2520484
Im just wondering, what card is this your talking about?
https://linustechtips.com/topic/187321-a-first-timer-needs-help/#findComment-2520518
thank u everyone i now know what to do get an adapter
what card are you even buying that only has VGA
https://linustechtips.com/topic/187321-a-first-timer-needs-help/#findComment-2520524
lol "get a card with proper ports" +1
+1 for real...as linus has said...please under no circumstance should you ever use that port,
If you've previously won the build off please pm me so we can get something worked out.
https://linustechtips.com/topic/187321-a-first-timer-needs-help/#findComment-2520526
yeah im not vey bright just realize there are hdmi ports after going back
I was going to say...that model should have a HDMI port on it.
https://linustechtips.com/topic/187321-a-first-timer-needs-help/#findComment-2520576
This should've been the very first reply instead of adapter suggestions (that will not work) to a nonexistent scenario.
ahaha I just read through all the replies. I'm pretty sure they're talking about a passive VGA to HDMI adapter, which doesn't exist.
"Rawr XD"
https://linustechtips.com/topic/187321-a-first-timer-needs-help/#findComment-2520599
