Shadowplay Problems
Solved by Archangel1994,
Recently I haven't been able to turn on shadowplay, I hit the switch to activate it but it just goes off after this: http://gyazo.com/707129c7d364ea46af9ccae03a7c77da Like it was never pressed. I've had no problems with it earlier and have been able to record & stream. I've tried re-installing the drivers, and trying the beta drivers, but neither worked.
PC specs are here: http://pcpartpicker.com/user/ZealotSlayer/saved/c4QRsY
Did you try reinstalling Geforce experience or was that done automatically with the driver reinstall?
